585,974 active members*
4,338 visitors online*
    May 2018
    5
    Boss Laser LS 2436
    Hey guys, new to the forum & have issues,
    I purchased a Boss LS2436 laser engraver/cutter & i'm finding that their cutting speeds are dif than most other companies, they are in mm/sec as opposed to %of speed (on a trotec/epilog)
    Anyone have an idea on the comparison ?
    I thought of calling them and asking, but they'd probably tell me to go kick rocks since i didn't buy one of their machines....
    2nd: the table comes with numbered scales, top & right side, but they are flat, not able to bank any work pieces against for alignment /re-positioning of work, did anyone make their own and mount them ?
    Thanks in advance !!!
    Dec 2018
    Re: Boss Laser LS 2436
    Im sure you have the answer to your questions already 4 years later , but full speed is 500 so as a percentage of 500 tells you the speed to set, I was wondering if you may have had any issues with replacing your lens and then precision and power being an issue, just had to replace my lens , it cracked after engraving 25 hockey pucks, and now with the new lens isnt as defined in precision engraving and seems to need more power to do the same jobs
  1. Rabbit Laser vs Boss Laser LS 2436, looking to buy, need advice
    By jram in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-19-2020, 10:23 PM
  2. Benchtop PRO 2436 Build
    By sparkness in forum Avid CNC
    Last Post: 11-21-2018, 02:03 AM
  3. Boss LS-2436 100W
    By evanslm in forum BOSS Laser
    Last Post: 05-03-2018, 07:34 PM
  4. Purchased a laser engraver, my experience with Boss Laser
    By indyglassman in forum BOSS Laser
    Last Post: 07-24-2017, 06:41 PM
  5. Replies: 3
    Last Post: 11-05-2015, 09:11 PM
