Need toolpath help please with square tube profile plasma cut
Hi there
I'm trying to to do a profile cut with a 4 axis plasma tube cutter on a square tube as the photo shows below. For some reason when I do a wrap around x it works in a circular shape and will cause the torch to touch the corners of the square tube. How can I go about this without needing to machine it on the mill. I will basically need it to follow the shape of the stock but only on the profile line.
Thanks in advance
Attachment 392412
If A is a success in life, then A equals X plus Y plus Z.
Work is X, Y is play and Z is keeping your mouth shut.
