586,000 active members*
5,031 visitors online*
    Apr 2013
    34
    Kflop dont print anything to the console
    Hi, Tom
    Everything worked well for a long time, but this morning KMotionCNC could not open the configuration file. I decided that I had some problems with the disc, checked everything, found nothing. I did not understand what happened, tuned KMotionCNC again. Everything seems to work, but KFlop does not print anything to the console, a command like printf ("Hello World!\n"); doing nothing. The version was 4.34j, I flashed the version 4.34k, nothing has changed.
    May 2006
    4045
    Re: Kflop dont print anything to the console
    Hi mk00,
    Strange. I don't know. Were you running multiple copies of KMotion.exe? You might check with Window task Manager.
    There should be a backup of the configuration file.GCodeConfigCNC.txt.bak
    But if you get an error it would indicate that wasn't found either.
    Otherwise can you list the exact steps you are doing?
    Regards
    TK
    http://dynomotion.com
    Apr 2013
    34
    After the weekend it worked. Nothing has changed. I think that the problem is in my PC. In any case, thanks for the reply.
  1. 2 in one... Sub-Console Part, Sub-Console Error.
    By Harryhutch in forum CNC Machine Related Electronics
    Last Post: 06-11-2015, 08:04 AM
  2. Support arm for HMI console?
    By JLRB in forum CNC Machine Related Electronics
    Last Post: 01-20-2013, 04:54 PM
  3. Replies: 3
    Last Post: 01-05-2009, 02:36 PM
  4. Portable Console
    By Rodm1954 in forum Benchtop Machines
    Last Post: 07-17-2008, 07:52 PM
  5. Mach3 console?
    By RLC in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2006, 07:50 PM
