585,752 active members*
3,824 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Power Drawbar cylinder teardown?
Results 1 to 6 of 6
    Jul 2006
    130
    Has anyone taken apart the air cylinder that sits on the spindle for tool changes?
    I've got some pretty bad leaks in mine that come and go as gunk gets pushed around.
    One in in the threaded area which is open do most people have a plug installed in there? Seems like it should have something. The other is the OD of the cylinder, it was pretty gunked up and probably created gaps in the seal.
    Jul 2006
    130
    Re: Power Drawbar cylinder teardown?
    This is a very different size but explains a lot. I have a big spanner on order we'll see how it goes Tuesday night.
    https://www.youtube.com/watch?v=qWLmq_biHyw
    Sep 2010
    529
    If you rare talking about the big pancake cylinder on top of the machine? Think it's about a 6" bore? I purchased a rebuild kid for mine, don't think I ever got around to rebuilding it. Info on the kit, it was rebuild kit for an RK6, cost $29.45 and I got it from HeiTek Industrial Automation in Phoenix, AZ. I would assume they have offices in other parts of the country.
    Jul 2006
    130
    Thanks Brian that's the one. I'll hunt down a kit.
    Jul 2010
    548
    Hi Yugami, If you have the "square" cylinder, The 4 lock nuts are held in with RED lock tite, get your propane torch out.
    I have rebuild kits for the "square" single stage cylinders.
    sportybob
    Jul 2006
    130
    It was round, the only issue with it was they were feading it dirty air and crud opened the seal just enough.
    Wiped everything down and relubed the gaskets and oring. Fixed a few of my plungers and everything is back up.
    Leaving town for the weekend but I'll be tackling the z tram on Monday.
  1. New Power Drawbar.
    By brianbonedoc in forum Novakon
    Last Post: 05-15-2021, 12:39 AM
  2. Help selecting air cylinder for power drawbar
    By Middlefart in forum Benchtop Machines
    Last Post: 03-05-2018, 02:48 AM
  3. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  4. High Tension Power Drawbar Using 3in Cylinder
    By LacL in forum Benchtop Machines
    Last Post: 08-14-2014, 01:39 AM
  5. Milacron 15VC machining ctr drawbar cylinder
    By ganzelc in forum Cincinnati CNC
    Last Post: 01-01-2011, 05:46 PM
