585,949 active members*
4,194 visitors online*
Results 1 to 16 of 16
    Sep 2009
    1856
    UCCNC G53 or G54
    Are there any issues useing G53 or G54 in UCCNC
    (1001)
    (TEST 4 AXIS)
    (T3 D=10. CR=0. - ZMIN=-10.1 - FLAT END MILL)
    G90 G94 G91.1 G40 G49 G17
    G21
    G53 Z0.
    G90
    or
    (1001)
    (TEST 4 AXIS)
    G21
    G54 Z0
    G90
    And haveing G54 Z0 at the end instead of G53 Z0 or G28/G30 Z0 at the end.
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Re: UCCNC G53 or G54
    I'm assuming you are creating or editing a Fusion 360 post?
    G53 Z0
    G54 Z0
    Neither of these lines actually do anything.
    Do you mean G0 G53 Z0?
    Personally, I remove that from my post. I don't want the machine to rapid all the way up at the start of my code.
    I also wouldn't want a G0 G54 Z0, as that could cause a crash.
    Also, G94, G91.1, G21, and G20 are not used in UCCNC. (Hopefully G94 will in the future, if the often requested G93 is added.)
    15362
    Quote Originally Posted by daniellyall View Post
    (1001)
    (TEST 4 AXIS)
    G21
    G53 Z0.
    G90
    or
    (1001)
    (TEST 4 AXIS)
    G21
    G54 Z0
    G90
    G53 and G54 are ( 2 ) very different Codes
    G54 through G59 Plus can only be used for your work offset
    A G53 can be used but not normally for a first move in your program and is normally use with a G0G53, if a G0 is active Like I show at the end of the program, then it can be used by it's self G53, not all controls support the use a G53
    G0Z100.
    G53X---Y---
    (1001)
    (TEST 4 AXIS)
    G90 G94 G91.1 G40 G49 G17 ( G94 and G49 is not needed in this line add a G80 )
    G21
    (T1M6 Tool number 1 This Line can be replaced with a safety Z axes move if you don't have a Tool Changer as below )
    G0Z100. ( It will move the Z axes, 100mm above the work, if everything has been setup correct, this only works if you have homed your machine correctly ) ( you can use any number you want )
    M8 ( only needed if you have coolant or an air blow Etc )
    G54 ( Work offset X0 Y0 start position of your work )
    G90G0X-----Y------- ( where you are going to start cutting )
    G43Z.1H1 ( G43 is your Tool offset Z axes will move to .1 above the part, this can be any number you want, H1 is your tool in the offset page )
    G1Z-0.06 ( this is the start of your program you are going to cut )
    G90 ( you have G90 in the Header so this is not needed again unless you use a G91 after a G90, if you use a G91 you must have a G90 for the next move after it's use, one cancels the other )
    End of program
    G0Z100. ( Z axes moves up 100mm to clear your work )
    M9 ( if you have coolant to shut off )
    M5 ( Turns spindle off )
    G53X------Y-------- ( Moves to where ever you want your part to be )
    Mactec54
    15362
    What is the use of a G93, I don't know of any time you would have a need for it, G94 and G95 are the only 2 feed codes that used for everyday use
    Do people even know what inverse time mode means
    G93, Inverse Time Mode ON, translates the linear (inches/mm) feedrate into a value that takes rotary motion into account. G93 specifies that all F (feed rate) values are interpreted as strokes per minute. In other words, the time (in seconds) to complete the programmed motion using G93 is 60 (seconds) divided by the F value.
    Mactec54
    Sep 2009
    1856
    It's more I just needed to know if G54 was a bad idea at the start and end of the G code for UCCNC yes ger G0 G54 Z0
    The newest UCCNC post for fusion has G53 one of the UCCNC users wonted his changed from G53 to G54 at the start and end.
    I will let him know that have G54 could cause a crash and where it goes its up to him to test it.
    mactec54 the chunk of G Code I posted is not the header from the UCCNC post it just has G90 in it, that was what I had open at the time I posted here.
    I know what G93, G94 and G95 are for
    [SIGPIC][/SIGPIC]
    Rotary axis work using G93 makes it easy to get the proper feedrates on the rotary axis moves on controls that don't sync rotary and linear feedrate.
    15362
    Well I replied to what you had posted, you gave 2 examples , I gave you what needs to be done to correct your Post processor
    Read the UNCNC Manual it will tell you the same as what I have Posted
    Snips below are from the UCCNC manual
    Attached Thumbnails Attached Thumbnails Using G53.jpg   Using Tool Offsets G54 Etc.jpg
    Mactec54
    15362
    This would help when you have 4 and 5 axes, but most good Cam program have moved past using a G93 as there are more efficient methods for doing the same thing, there are some 3rd party programs that offer the use of G93
    Mactec54
    Feb 2018
    20
    [snip]
    [snip]
    Sorry Hijack.
    I have just spent a while in the last couple of days trying to find out if that was normal... I have been manually editing out the G0 G53 Z0 from the start (and end) of the F360 produced Gcode and I'm glad it's not just me that found it strange.
    Is there an option in F360 to suppress this, or I guess is there an option to edit the F30 Cam definition to remove it?
    It's not the end of the world to have to remember to take it out manually, and I do have a Z limit switch, but it is annoying.
    Cheers - N
    Jun 2015
    943
    Quote Originally Posted by Talkiet View Post
    Sorry Hijack.
    Cheers - N
    I'm not using Fusion, but the code which outputs that G53 should be in the post processor.
    Try to check the post processor file and find where it posts that piece of code.
    Or ask Autodesk customer or tech support about it.
    Sep 2009
    1856
    Talkiet That is a simple edit I do that one all the time, I usely have it so it is a G53/G28 or a set position what is just a yes no selection to change it or G53/G28 and a nothing.
    I can do it for you or just tale you, You just have to make sure that the post is keeped up to date with the code changes, they are slow make it so a post edit is simple as mud useing the Visual studio editor they have done and have a end or start code different to in the G code it self.
    Whats is a pain haveing to redo posts each big update of the CAM.
    [SIGPIC][/SIGPIC]
    Feb 2018
    20
    I'm comfortable coding etc so I'll have a look around first before asking for specific assistance - just knowing that I need to edit the post proc file is the hint I need.
    I also need to modify the 2017 screenset to include the homing offsets - although I can manually put the parameters into the profile config, and they are loaded and used fine, the screenset overwrites them with zeros when I save it again...
    I guess it's time to break out notepad++
    Cheers - N
    Do you mean the homing backoff distances from the test versions? Just use the screen editor to add the fields somewhere.
    Feb 2018
    20
    Sorry, yes, I mean precisely the homing backoff distancesfrom the test versions. I just checked and they solve my prox sensor getting stuck in limits after homing perfectly.
    (The offsets that are in the production versions don't help)
    Cheers - N
    Feb 2018
    20
    Thanks for the suggestion Gerry - I added the X/y/z homing backoffs tonight and it works perfectly with the screenset.
    Cheers - N
    Jun 2015
    943
    Cheers - N
    The offset is the home coordinate it does not back the axis off is why it does not help for your problem.
  1. UCCNC ETH-400
    By SCzEngrgGroup in forum Novakon
    Last Post: 05-12-2020, 12:16 PM
  2. UCcnc CAM
    By vmax549 in forum UCCNC Control Software
    Last Post: 09-16-2016, 04:19 PM
  3. Uccnc - g20/g21 or g70/71
    By robertspark in forum UCCNC Control Software
    Last Post: 06-19-2016, 01:26 PM
  4. UCCNC Help
    By extsuba in forum UCCNC Control Software
    Last Post: 04-08-2016, 05:51 AM
  5. Has anyone really used UCCNC?
    By greggv in forum UCCNC Control Software
    Last Post: 08-16-2015, 10:45 AM
