585,902 active members*
4,096 visitors online*
Results 1 to 18 of 18
    Jun 2014
    1780
    Ballscrew backlash
    I have some backlash in the Y axis, about .0024 approximately, is there an adjustment to the ballnut for this?
    I have adjusted the preload, tightened up the carrier, it wasnt loose but definitely not tight, the backlash is still there.
    I am wondering if there is a rebuild service for these or something short of buying a new one, as its $522.00.
    I noticed this in a probing sequence, in X it is smooth, in Y it makes a slight "bump" when the Y axis reverses which prompted me to look for a problem.
    Any help or information would be greatly appreciated, as I know very little about Ballscrews............
    This is on a PCNC1100 series 3.
    mike sr
    Dec 2008
    740
    Ballscrew backlash
    Quote Originally Posted by popspipes View Post
    Hi Mike
    "a slight bump" is a little difficult to diagnose. The Ballnut itself is not really intended to be user serviceable (but some have reportedly done it). The ballnut housing could be loose but that's not likely to cause a bump.
    Is your Y gib perhaps too tight?
    Step
    Edit: a short video might help us.
    Jun 2014
    1780
    Re: Ballscrew backlash
    Quote Originally Posted by TurboStep View Post
    Hi Mike
    Step
    Its a bit hard to describe, it shakes the machine slightly when Y reverses direction, I can try to video what is happening, its similar to an abrupt stop and start (accel decel not set correctly) is how I would describe it, on the Y axis only, the X transition is very smooth.
    There are a few very tiny flakes which appear to be metal on the screw itself, it is a bit oily but not profusely so.
    It isnt really noticeable except when probing a pocket, moving the Y manually its very hard to notice unless you know its there and are looking for it. The probing routine changes from Y- to Y+ immediately, that makes it very noticeable.
    cost is a bit of an issue but not near the issue of removing and reinstalling!!
    mike sr
    Sep 2009
    624
    Saunders just (well, last month or two) posted something on this, I think.
    https://www.youtube.com/watch?v=z6RzDphty_o
    there's some earlier stuff too:
    https://www.youtube.com/watch?v=dDuPcSKb6uk
    Jun 2006
    3063
    I had some backlash in X a while back that was caused by loose fasteners on the X-axis carrier, so maybe something similar is happening with the Y axis carrier on your. The Y carrier looks a bit harder to get to than the X carrier, unfortunately.
    Sep 2006
    245
    Quote Originally Posted by MichaelHenry View Post
    Searching for a loose component would also be my first plan of attack.
    If it turns out that the ballnut is actually worn, then it may be possible to re-pack the ballnut with slightly larger balls. This works best if the screw is worn evenly. It may cause binding near the ends if only the center portion is worn. There may be services that re-build them. Not sure about the cost or how to find them.
    Steve
    Jun 2014
    1780
    Quote Originally Posted by steve323 View Post
    Steve
    Mike, Steve,
    I have checked for loose fasteners etc, now that I think about it, 6 years of making the same small parts with a 3d hole in the center that takes37 to 62 passes roughing, the same for finishing times a thousand or so pieces could be the reason for the bit of backlash possibly??
    I have approx .0024 backlash in the Y, I only notice the abrupt start stop in the pocket probing routine. I need to move some shelving to get at the Y stepper area, so it may take awhile before anything gets done......................
    thanks for all the suggestions!
    mike sr
    Jul 2007
    1602
    Mike, Steve,
    Is the backlash the same across the travel? If not perhaps you re-fixture the parts so that the critical feature is on a good part of the screw.
    bob
    Jun 2014
    1780
    Quote Originally Posted by rowbare View Post
    bob
    I tried this and it doesnt seem to change, I need to take it out and find whats causing the problem, its not that bad but needs fixed but its more of a winter job, too much stuff going on now..........
    I am thinking a 4" knockout cutter thru the bottom of the stand, then make a plug with an oring seal?? I was also thinking 3" risers under the machine and on top of the stand, but I would need to make a platform for the operator to stand on.............
    just cant seem to win for loosing Ha!!
    thanks for the suggestion.
    mike sr
    Aug 2016
    132
    Does adding backlash compensation to the INI file help at all? I think ALT + D gets you out of PathPilot and on to the main screen, but I'm not 100% sure.
    Jun 2014
    1780
    Quote Originally Posted by footpetaljones View Post
    I had backlash set for each axis, it left witness marks in the part at 90 degree intervals so I took it out.
    The Y axis had the abrupt stop start in it with or without the backlash setting.
    ctrl+alt+x is how I get to the terminal.
    tnx for the suggestions.
    mike sr
    Mar 2010
    60
    Interesting idea cutting hole out to get at ball nut. The thought of lifting and supporting the mill whilst ball screw maintenance is carried out fills me with dread. Hopefully I won't have to. Let us know how you get on. I have never tried using such a large hole cutter on steel.
    Jun 2014
    1780
    Quote Originally Posted by John Roberts View Post
    I had cut two 1" holes in the pan, tightened the yoke, and welded them back up, (the reason for two holes is the first one needed tp be back 1" farther to reach the back two screws). I did shut everything down and remove all power to the machine first. I just didnt want to deal with raising the machine , make the repair, then retramming it.
    I think a 4" knockout cutter, and a custom made plug and oring may fill the bill............Then access to the oil lines and any other maintenance issues would be so much easier.
    mike sr
    Nov 2007
    2151
    Did this help the Y backlash Issue?
    Jun 2014
    1780
    Quote Originally Posted by mountaindew View Post
    no it didnt, the yoke was not torqued very well, but that wasnt the source of the backlash. I have to remove the ballscrew but cant get to it right now, as I have some free standing shelves behind the machine to move back a couple feet.
    I have a 2 car garage but it is full............
    mike sr
    Feb 2016
    82
    You are referring to the yoke that is bolted to the carriage for y travel? You can remove the way covers and get a socket wrench and allen head in there. If I'm miss understanding, I apologize ahead of time.
    Jun 2014
    1780
    the screw is in the way of getting your hand in there. the stand should have been designed with an access cover in the bottom of it, Those mounting pads on the stand are welded to the 10 gage floor, there are no vertical supports under the pads, one needs to be careful putting in access ports in the bottom as it would/could affect structural integrity.
    I will get it, at my age it just takes some time ha!
    Yoke is probably not the right word, it is the ball nut carrier that bolts to the table.
    mike sr
    Nov 2007
    2151
    I did this a couple years ago with same results. Please post what you do about this. I will follow and do same. I have some parts for this rebuild like bearings, washers, … was hoping someone would do this so I could have more confidence in a procedure.
  1. BALLSCREW BACKLASH
    By plast744 in forum Milltronics
    Last Post: 10-30-2013, 04:25 PM
  2. ground ballscrew backlash
    By nc_machine09z in forum Machines running Mach Software
    Last Post: 06-12-2012, 06:17 AM
  3. 3016 ballscrew backlash
    By Daniel Boone in forum Fadal
    Last Post: 07-20-2010, 07:00 PM
  4. Ballscrew backlash, need suggestions.
    By magick_man in forum DIY CNC Router Table Machines
    Last Post: 05-05-2007, 11:36 AM
  5. Backlash for a rolled ballscrew?
    By Zumba in forum Linear and Rotary Motion
    Last Post: 03-20-2006, 10:41 PM
