585,743 active members*
5,132 visitors online*
Results 1 to 6 of 6
    Jan 2016
    25
    1/4-20 slot nuts
    Been thinking about some 1/4-20 hold-down solutions to compliment my 10-32 stiff, mainly for compatibility with some 1/4" accessories I have.
    Toying with a few options,
    • T-nuts: Raised nut design, also will serve as hold-off (maybe only raised 1/8")
    • T-bolts: Some off the shelf 1/4 hex head bolts + "head carriers" to prevent spin and contact with slot walls
    Some simplified drawings I made real quick in MS paint, sorry, CAD license is being used by someone for "real work" at the moment.
    5/16 would be be great too, but would require even more elaborate workarounds, prob gonna focus 1/4-20 for now.
    Wondering mainly if anyone has tired similar with/without success.
    Nov 2016
    5
    Re: 1/4-20 slot nuts
    Your an innovator, nobody has made t nuts before. ..
    Sent from my SM-G900T using Tapatalk
    Jan 2016
    25
    Quote Originally Posted by adchrome View Post
    If someone has made 1/4-20 t-nuts that fit taig slots, please let me know!
    In case you are unaware: Taig slots are too small for standard 1/4-20 t-slot equipment.
    Nov 2016
    5
    Quote Originally Posted by averageJoe576 View Post
    Just messin with ya, make them out of steel so less chance stripping threads. ..may be better off with 1/4 - 28
    Jun 2011
    692
    I'm having a hard time seeing how the I beam shaped nut would be used. How would it be secured to the table?
    Jan 2016
    25
    Quote Originally Posted by skrubol View Post
    They would secure like a regular nut, but the part couldn't be in contact, so I was wrong about "and could be used as a hold-off". Given that, maybe they aren't worth the trouble. I may look at something more like a mini-fixture table.
    But I think the hex head "carriers" will work out. Currently thinking something like this (drawn to scale). Basically it just prevents turning and the hex head digging into the t-slot walls. Could get fancier with the pocket design if it turns out to have durability issues, but would need to use a smaller end mill.
  1. Steel nuts binding - would acetal nuts be better?
    By rhysun in forum Linear and Rotary Motion
    Last Post: 11-19-2016, 01:13 PM
  2. T-slot nuts for Taig
    By surrealism in forum Taig Mills / Lathes
    Last Post: 04-24-2010, 11:11 AM
  3. Where to buy loose 8mm T-Slot nuts and 6mm Clamping Studs
    By Hackman in forum Benchtop Machines
    Last Post: 09-08-2007, 05:57 PM
  4. T-Slot nuts for Taig!
    By Stuff-Builder in forum Taig Mills / Lathes
    Last Post: 07-27-2006, 10:58 PM
