Hi All what has happened to the Gcode Wizard in CNC TNG ?
I have used this to make cylinders from blocks now its not there
User Defined list don't have it either ?
Also what post processor is used from Vectric to create Wrapped Gcode.
Which feature do you have in mind?
Could you post screenshot of the wizard dialogue?
On file G-Code Wizard CNC USB
On CNC TNG User Defined
In TNG you can create your own "wizards". They are called "User defined". "Round pocket" and "Straight pocket" are already included and are named "Pocket 1", "Pocket 2" and "Pocket Rect".
You are missing "Rotary Roughing"? I added it to out TODO list But you can also make it yourself.
Thanks for your reply I will hold on until its released then i have no idea of programming script :-)
Have you any idea about which post processor to use for Rotary carving from Vectric ?
I would also like an answer for the vectric rotary question.
Thanks - I cannot join your search for a couple of weeks as just finishing 4th axis build. But would be grateful to know your test results.
Will Do Buddy is feels like top secret sometimes getting simple information or no one carves cylinders
Have a look at GCode Ripper it has a Wrapping feature but i need to give it some testing as well
