585,973 active members*
4,128 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Cannot produce radius
    Feb 2018
    Hello,
    I have a kidney shaped pocket 40mm wide and 40mm deep in the part Im machining. The pocket has a 10mm radius around the top edge. i have produced the slot to size but i cannot get the Edgecam to produce a radius around it. I cant seem to get the "Find Features" tab to recognise the radius separately from the pocket.
    Im currently using a 16mm endmill to produce the pocket if this helps.
    Any help much appreciated.
    Dec 2008
    441
    Re: Cannot produce radius
    Hello!
    Maby i don`t understand our problem, but if you have the latest software (2018R1) you can pick the solid face in a profiling cycle i think. Try that
    And if you use Cusp Hight, you can get the radius fine
    Post a pic if you can!
    -Robert
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Sep 2008
    8
    What you would normally do is forget the radius and pocket the inside as normal then use a ball nose (10mm + in your case) and use flow surface cycle with blend between curves set. Select the radius all the way round, select the top edge chain and select the bottom edge chain and scan the radius.
  1. Radius to end of arc differs from radius start
    By Don C in forum Dolphin CAD/CAM
    Last Post: 06-29-2014, 04:46 PM
  2. Small radius good Large radius bad
    By K2Developmentab in forum Fadal
    Last Post: 09-26-2013, 07:26 PM
  3. Replies: 1
    Last Post: 05-15-2013, 08:52 AM
  4. 021 start radius end radius error
    By XAD in forum Tree
    Last Post: 06-01-2012, 04:59 PM
  5. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
