585,930 active members*
4,077 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Understanding manual tool release wiring diagram for HSD ES919 Spindle
Results 1 to 6 of 6
    May 2011
    36
    Hey Guys I'm struggling understanding how to wire up my HSD manual tool release and was looking if someone can help me figure this out!
    So im confused how to hook up the wires on the pigtail. I understand pin 7 wire will go to a 24v power supply, I dont understand what I connect the pin 8 wire to? Is "P" something I have to add or something that was possibly on the old Controller board or something inside the spindle itself? Andddd I dont understand "C" and "E" lol Any help would be greatly appreciate!
    -Benny
    May 2011
    36
    Re: Understanding manual tool release wiring diagram for HSD ES919 Spindle
    So I discussed this further with a friend and I think I have a little better understanding-- or at least enough to test a theory. is the 8 "Button Output" an optional connection for an external control? IE controller software?
    Jun 2011
    692
    Looks like the button just connects pins 7 and 8 on the connector. You need to supply 24V power and an air solenoid at the minimum.
    Jun 2013
    6
    Quote Originally Posted by muibubbles View Post
    -Benny
    I am in the same situation, I only want to use the button to do tool changes. Did you ever figure this out?
    thanks
    Rob
    Jun 2013
    6
    Ok, I got it...
    It is all about the solenoid (Not Supplied). I originally thought the their was a solenoid within the unit itself.
    Need to wire 8 pin (Button output) inline with the solenoid (Normally Closed).
    Quote Originally Posted by rchristie View Post
    Ok, I got it...
    Hello . I have the same problem. I have a es929 but can not figured out how to put it to work the release tool.
    Can somebody help?. And explain about the solenoid and the pin 8
  1. HSD SPINDLE MANUAL TOOL RELEASE BUTTON LIGHT IS.OFF
    By M.Abid in forum Chinese Machines
    Last Post: 08-06-2015, 09:06 AM
  2. Enshu. DT Centre Wiring Diagram Manual
    By diamondyarn in forum Machinery Manuals / Brochures
    Last Post: 05-04-2015, 07:14 PM
  3. Dyna Myte 2400 manual+wiring diagram
    By ysihonda in forum Benchtop Machines
    Last Post: 02-26-2015, 09:25 PM
  4. Water chiller Cw3000 & CW5000 Manual and wiring diagram
    By Gweikelasers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-03-2014, 08:15 AM
