585,758 active members*
4,369 visitors online*
Results 1 to 9 of 9
    Aug 2015
    38
    Problem with cuts
    Hi all! I am having a problem while cutting MDF with my CNC.
    The thing is that where the start node is, the router seems to go a little inwards and ruins the straight edge. I am not sure if I have explained myself correctly, so a picture will illustrate my problem better
    Also, here is my cnc code, generated with ArtCam (the piece is a rectangle BTW)
    Code:
    G90
    G49
    M3 S15000
    G0 X423.330 Y198.500 Z5.000
    G1   Z-3.100 F3000
    G1 X1.500   F4560
    X1.500 Y1.500
    X438.500 Y1.500
     Y198.500
    X423.330
    G1   Z-6.200 F3000
    G1 X1.500   F4560
    X1.500 Y1.500
    X438.500 Y1.500
     Y198.500
    X423.330
    G0   Z5.000
    G0 X0.000 Y0.000
    G0Z5.000
    X0.000Y0.000
    M05
    M02
    Any help will be highly appreciated.
    Regards!
    Jul 2016
    660
    Re: Problem with cuts
    Maybe because your code starts somewhere in between 3/4 of the face and ends at the same spot before it zeroes itself.
    You can start diving your spindle at Zero itself, no need to reposition it to a different location, in that way you eliminate the jiggling while the spindle is on dive mode and end mode, you can also adjust the plunge feed rate to avoid jiggling while it`s diving, can you post the actual dimensions on your route path? I can make a sample code for you that`s not really aggressive while diving, start @ zero itself and ends @ zero, it can also be multi passed to avoid excessive vibrations while cutting the material.
    Aug 2015
    38
    Hi! Thanks for the reply. I dont think that that would solve the problem, becuase if I have to cut 2 ( or more) pieces, only one would be placed at 0,0 and not the rest. Am I correct?
    What I don't get is that if the spindle lowers at the Start Node, and then goes in the direction of cut, how can the start point be inwards and not the rest of the cut?
    That means that the spindle is going down in the start node, spindle goes outwards a little bit and then makes the rest of the cut. Makes no sense to me at all.
    Regards!
    Jul 2016
    660
    Well it cuts perfectly straight on my code simulator, I think there`s an outside factor that causes it to mess with a straight route path, things like backlashes (X and Y axis), or noisy power supply that messes the stepper drivers and goes offset a little bit and back again, semi stuck ball screws. on my opinion the code is perfect even though it does`nt start @ zero.
    With a route path
    Without a route path.
    Hint: even if you cut a hundred parts in one MDF board you can still dictate where to start in each and every route path you created, that`s what CAM programming does, You can take control of your spindle from start to finish.
    Aug 2015
    38
    But is it possible that I have that problem exactly on each Start Node and nowhere else?
    Regards!
    Jul 2016
    660
    Quote Originally Posted by inicdam View Post
    Regards!
    Maybe only one way to find out, try another code that starts cutting at the edges and ends also @ edges of the rectangle, or post your rectangle dimensions here, let me code it for you starting @ 0,0,0 axis, specify also how thick is your MDF in mm, I dont use inches in my CAM coding.
    Aug 2015
    38
    Alright. I can try with a 10 x 10 cm square.
    Appreciate your help
    Jul 2016
    660
    Ok here`s the code, I just assumed that your cutter diameter is 1/4, then the material is 3/4 I lowered the feed Rate to 2000 and the plunge rate to 1000 and the spindle speed @ 15K RPM just to try it out.
    "Single Pass"
    G90
    G0 Z3.0
    ( T0 : 0.0 )
    T0 M6
    ( Pass 1 )
    G17
    M3 S15000
    G0 X0.0 Y0.0
    G0 Z1.0
    G1 F800.0 Z-19.0
    G1 F2000.0 X103.2
    G1 X117.4
    G1 Y-106.4
    G1 X0.0
    G1 Y0.0
    G0 Z0.0
    M5
    M02
    Then Multi pass by 4 also just to try it out
    G90
    G0 Z3.0
    ( T0 : 0.0 )
    T0 M6
    ( Pass 1 )
    G17
    M3 S15000
    G0 X0.0 Y0.0
    G0 Z1.0
    G1 F1000.0 Z-4.75
    G1 F2000.0 X103.2
    G1 X117.4
    G1 Y-106.4
    G1 X0.0
    G1 Y0.0
    ( Pass 2 )
    S15000
    G1 F1000.0 Z-9.5
    G1 F2000.0 X103.2
    G1 X117.4
    G1 Y-106.4
    G1 X0.0
    G1 Y0.0
    ( Pass 3 )
    S15000
    G1 F1000.0 Z-14.25
    G1 F2000.0 X103.2
    G1 X117.4
    G1 Y-106.4
    G1 X0.0
    G1 Y0.0
    ( Pass 4 )
    S15000
    G1 F1000.0 Z-19.0
    G1 F2000.0 X103.2
    G1 X117.4
    G1 Y-106.4
    G1 X0.0
    G1 Y0.0
    G0 Z0.0
    M5
    M02
    Just copy and paste the code in notepad then save it as .nc or .txt
    Aug 2015
    38
    Thanks for the help, but the issue seems to have been a problem with my code because I am not having this issue anymore
    Kind regards
  1. New Tube but only cuts for 30second then laser cuts out
    By JBxrayman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2016, 05:57 PM
  2. Good Cuts, Bad Cuts
    By JSR03 in forum Fanuc
    Last Post: 03-30-2016, 09:37 PM
  3. Does tool life vary with interrupted cuts to continuous cuts
    By acejunker in forum MetalWork Discussion
    Last Post: 08-08-2014, 02:34 AM
  4. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  5. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
