585,743 active members*
5,108 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need help with NPT threads in Mastercam x9
    Apr 2018
    5
    Hi guys,
    Please school me.
    I draw this NPT internal threads following the drawing but it's over-sized. is there something that I should do more than the drawing, right?
    I found dimensions but I dont know how to put it into Mastercam.
    Thank you guys.
    May 2013
    149
    You have to go the long hand way without cam, im thinking helical interpolation programmed in quadrants. Maybe use mastercam to draw a 3d spline of your tapered thread, break spline at qaudrant with line in 2d views and then use convert to arcs feature to obtain polar information to write program. It should read something like G3X10.Y10.Z-3.R10. And automatically should calculate the polar anchor point. Repeat this for however many quadrants, if one decimal place is wrong then all the code will fail.
    Wisdom results from foolishness!
    May 2007
    1003
    Re: Need help with NPT threads in Mastercam x9
    No version of MC will do that thread that I know of. At least not in the normal way a thread is done. The 3/8 in. straight section is the killer. You probably could make a thread with zero lead-in and 0 degree infeed. However, I don't know how good the beginning of the thread would be. I've done some threading with a very short starts before the material. RPM has to be held down so the turret can accelerate to the correct feed in a short distance.
    Personally I would write it long hand and hope for the best. Too bad many engineers and designers never actually know how to machine a part.
    May 2018
    7
    Use a grooving cycle and edit your post to output G92 moves
    :0001
    G21
    (ROUGH SCREW CUT ACME THREAD FORM)
    (THIS PROGRAMME IS TO RUN IN CONJUNCTION WITH.....)
    ( ROUGH THREAD )
    ( TOOL - 1 OFFSET - 1 )
    ( LGROOVE 3MM BUTTON )
    G0 X300.000 Z300.000
    G99
    G0 T0101
    G97 S600 M03 M41
    G0 X48.196 Z-9.586 M8
    G92 X43.451 Z-146.000 R0 Q0 F6.35
    G00 Z-9.586
    Z-9.289
    G00 Z-9.289
    Z-9.884
    G00 Z-9.884
    Z-8.991
    G00 Z-8.991
    Z-10.182
    G00 Z-10.182
  1. Does Mastercam do special threads?
    By fordav11 in forum Mastercam
    Last Post: 10-19-2016, 01:34 PM
  2. Replies: 0
    Last Post: 09-14-2016, 08:15 PM
  3. Replies: 5
    Last Post: 10-31-2012, 02:44 AM
  4. Tapping threads on VM1- from MasterCam
    By mafitch7479 in forum HURCO
    Last Post: 07-01-2011, 05:07 PM
