dont know how to navigate this forum stuff .but im trying to build cnc cutter .got every thing hooked up on tb6560 but all stepper does is lock up and cant use manual pad to make it move .any help would be appreciated.
I have almost exactly the same problem.The machine is ready to be motorised and I have the motors and drivers connected to a DB25 1205 board and a 36 volt power supply.When I test the axes using LinuxCNC,the voltage at the terminals of the board and the drive modules seems to be as expected.Nothing moves though in spite of the feed to the Nema 23's being present.Will I also find that nobody has any suggestions?
