I built a new cnc machine and I have a problem in zeroing so i will try again now
Sent from my SM-J700H using Tapatalk
hi Guys
have run my machine with Greolt's Aussie tool Setter for a number of years and everything worked well.
had to change computers recently and now running Windows 10 with ESS SmoothStepper. All if fine apart from the Tool Setter now not working.
I have tried using Greolt's 'Modified 1024 screenset and the probe/Touch plate registers on the LEd and in the Diagnostics page. I have set the thickness of the touch plate, however, it always seems to hang at the "G4 P3" - "G90 G31Z-4. F4" section.
Any ideas - it is driving me nuts.
Using CNC4PC C10 Bob's - work well - and the inputs set to 'Pull High' and the Pins sets to 'Active Low'. The input pins are at 4.98v.
Any and all suggestions greatly appreciated.
Cheers
Noel :cheers:
