Thanks Andrew. I think I understand what you mean.
I have spent all day researching and I think I will try and build my own machine.
I think I can do what I want with a fixed gantry machine and potentially no x-axis. Just y, z, and the 4th (a) axis. (Maybe I am confusing x and y?). Will that even work with the standard software?
[I can picture a dedicated 4th axis machine doing this without a Y axis (by convention, the longest axis is called "X"). As was suggested, DeskProto will write code for a setup like that, using an "along X" strategy, incrementing in A.]
Anyway, with 1605 ballscrews, HIWIN linear rails, NEMA 23 stepper motors, can I get by with cheap aluminium extrusion for a fixed gantry frame?
[Since a design like that would have the Z axis moving along a rail mounted to a fixed bridge, you don't need to use aluminum (which isn't cheap, compared to steel). The only reason to use it is to save weight on a moving part. Steel is stiffer as well as cheaper.]
I will probably want to buy a prebuilt z-axis and a-axis. Does anyone have any recommendations or links?
[There was a fellow who posted not long ago who was talking about building a machine based on a wood lathe frame. Your machine could be done like that; it would give you a way to mount the tailstock so it could slide back and forth. You can also look for precision automation actuators for the Z (and possibly the X). These have the advantage of being pre-built with rails and screws already in place, mounted in an extrusion and lined up correctly with a motor mount. They don't seem as common on Ebay Australia as here in the States, but you can probably find them there, or pay a lot of shipping costs:
https://www.ebay.com.au/itm/Parker-P...EAAOSwzJ5XaFF3
For the A axis, you can use a rotary table like the one Sherline makes, that has a mount for a 23-frame stepper:
https://sherline.com/product/3700-cn...rotary-table/]
Also what type of spindle/router will I need for hardwood/HDPE?
[A 3-phase spindle with VFD (like those already suggested) will work better than a hand router.]
Finally, does anyone has any recommendations on drivers and software for this build?
Regards,
James
