585,997 active members*
4,847 visitors online*
    Apr 2010
    25
    RoboDrill Fanuc 368 serial data error
    I get a 368 alarm on the Z axis of a Robodrill.
    I swaped the encoder and the cable with the y axis to check which one is the culprit. Both work fine.
    I imagined it should be the drive card from the driver. I have H209 for X,Y and H105 for Z axis.
    I also have a spare H207.
    I took out the drive card from the H207, and mounted it in the H105.
    I still get the alarm. I either have two broken drive cards, or the problem is somewhere else. Servo card is one year old, so I doubt it.
    Any ideas from someone with experience?
    Mihai
    May 2016
    526
    Re: RoboDrill Fanuc 368 serial data error
    Did the alarm move to the other amplifier ?
  1. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  2. spindle serial link error 750 Fanuc 21i
    By Abdul Haq in forum Fanuc
    Last Post: 07-13-2021, 03:09 PM
  3. Fanuc Robodrill 16M Control Error Code 101 - How To Remove?
    By Wick001 in forum Uncategorised MetalWorking Machines
    Last Post: 05-12-2011, 12:09 AM
  4. 18i-T = 368 B AXIS: Serial data error (int)
    By padobranac in forum Fanuc
    Last Post: 03-16-2009, 12:04 PM
  5. spindle serial link error 750 Fanuc 21i-MB
    Last Post: 05-13-2008, 11:59 AM
