585,987 active members*
4,198 visitors online*
    Jan 2016
    25
    spindle stop / mount test indicator
    Seems like a silly question, but: how to you properly stop the spindle from spinning when using a test indicator?
    Like in this video: https://www.youtube.com/watch?v=WbYtVwBzDko
    Or if someone has a different method entirely would be interested in that as well.
    I have this indicator set from LMC fwiw:
    https://littlemachineshop.com/produc...ProductID=2925
    Jan 2016
    25
    Re: spindle stop / mount test indicator
    No one?
    Feb 2010
    155
    On my Taig, I jam a piece of foamcore between the pulley and spindle body to prevent the spindle from rotating (low-tech but it works). You could also machine a spindle lock that uses a wrench head to lock the ER16 nut in place, like so:
    Taig Spindle Lock
  1. Dial Test Indicator Flaw
    By Zirok in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2012, 08:04 PM
  2. I really havent seen such behaviour of dial test indicator
    By Ashish B in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2011, 10:39 AM
  3. Spindle Mount Indicator
    By behindpropeller in forum Haas Mills
    Last Post: 08-07-2009, 08:13 PM
  4. E-stop and Fault indicator HELP
    By luis_gts in forum Viper Servo drives
    Last Post: 05-04-2009, 09:20 AM
  5. Enco or Mitutoyo test indicator?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 01-03-2006, 04:38 PM
