Hello all,
Just changed the tube in my 60w Chinese unit and was double checking the setup options on lasercad ver 7.58 and the awc608 controller. All seemed to go ok until I loaded the first file and tried to run it.
The controller displays the warning BEYOND SIZE! CONTINUE? If I continue, after messing around with the origin point, I can cut the file.
Had this same problem a few years back and just cannot remember what was done to correct the problem back then.
Checked the work table size and it is correct, also the size of the cad drawing table, and both are the same.
I know it's something obvious but just not seeing it.
Anyone have the answer??
Rick
