585,567 active members*
3,553 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HELP PLEASE PROGRAMMING VARIABLES
    Jan 2007
    23
    I'm on a 97 VF-3 and have a bunch of open ended slots to do of varied lengths.
    We do not have macro (I should be so lucky). My CNC programming software is SURFCAM but I don't want to re-program for every part.
    How could I go about programming these with just changing a number for the OAL and/or width?
    Is there a place on the web that explains parametric programming?
    software version 9.39N
    Thanks in advance
    T
    May 2006
    803
    Re: HELP PLEASE PROGRAMMING VARIABLES
    Please post the print or problem, no mind-readers here, yes there are parametric programs.
    Been doing this too long
    Jan 2007
    23
    Quote Originally Posted by bostosh View Post
    I have 25+ different lengths of tooling that need a groove cut in them .33 wide by .14 deep.
    I would like to be able to just enter the OAL as a parameter and go. Something an operator can do without changing a bunch of numbers. It sounds simple enough but I have doubts of doing it without the macro option.
    Jun 2015
    119
    I don't think you are going to get that done without macros. Well, how many passes are you making? Could you maybe prgram in incremental, at least for the length? Then you could maybe only have to change one or two numbers in a program. Not exactly the same as programming with macros, but it could save you from having to repost the program for different lengths.
    ____________________________
    My blog: http://www.fletch1.com
    Jan 2007
    23
    I am just hoping to find something a button-pusher could do. I do miss macro programming.
  1. 840D programming questions (loops, variables, etc)
    By Argv in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-27-2013, 04:17 AM
  2. G68.2 variables
    By Blunder in forum Fanuc
    Last Post: 12-10-2012, 11:52 PM
  3. New to variables need help with this one.
    By avirostick in forum G-Code Programing
    Last Post: 09-23-2012, 12:07 AM
  4. Variables
    By kz1000 in forum Mach Wizards, Macros, & Addons
    Last Post: 12-18-2009, 12:04 AM
  5. Variables 500 to 531
    By viorel26 in forum Fanuc
    Last Post: 09-30-2007, 08:30 AM
