585,981 active members*
4,288 visitors online*
Results 1 to 3 of 3
    Sep 2021
    The machine stops several times...
    Hey everyone.
    I´m working with CNC USB controller software and my CNC machine stops many time times while running differents G-code. It can perfectly work for some weeks or make stops several times in a few minutes.
    The machine normally works, but then the X,Y,Z values no more change in the CNC USB software. After that the machine move really slowly, I think it go back to the previous line of the G-code and stop.
    I have to reset the controller (machine/firmware/reset controller) and the machine work normally until the next stop.
    I,ve checked the USB connector and changed the USB cable, I´ve checked the ground conection of the power supplie but I had the same trouble. I´m working with a notebook....
    Do you have any heps about this trouble?
    thanks to everyone in advance
    exe
    Aug 2020
    131
    Re: The machine stops several times...
    are you running some additional software on the system while you run planet cnc?
    In the past I had significant issues running planetcnc tngv2 and fusion 360 in parallel. From time to time tngv2 froze and stopped working.
    Sep 2021
    Hey scorption,
    No, it desn´t run any other software. I use this notebook only to control de CNC machine. I tried to turn off the wi-fi connection adn the antivirus (AVG antivirus)... but I had the same troubles.
  1. Machine Stops or Runs Away
    By mw569 in forum Fadal
    Last Post: 03-11-2009, 07:02 PM
  2. Machine stops Help!
    By njitnjau in forum K2CNC
    Last Post: 11-17-2008, 07:20 PM
  3. Machine suddenly stops
    By ace8 in forum Hobbycnc (Products)
    Last Post: 09-07-2008, 06:10 AM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
