585,753 active members*
4,432 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Advice needed regarding the parallel card to CNC4PC comunication.
Results 1 to 2 of 2
    Nov 2017
    Lightbulb Advice needed regarding the parallel card to CNC4PC comunication.
    Good day.
    So a bit of background on my problem. We manufacture CNC fences for panel saws using a single stepper on a ball screw that is controlled by LinuxCNC via a parallel card to c35s CNC4PC board. We have been using this method for many years and now the sunix parallel card does not get manufactured anymore and different EPP , IE1284 cards just wont work.
    I am looking to upgrade the use of a parallel card to Ethernet but i am not sure what cards would be the best replacement. I know MESA makes quite a few boards as well as CNC4PC.
    Any recommendations would be thoroughly appreciated.
    Feb 2008
    644
    Re: Advice needed regarding the parallel card to CNC4PC comunication.
    Quote Originally Posted by RvanGreunen View Post
    Good day.
    I guess there are a couple ways to approach this, one is to search for a parallel port card that does work, for this, asking on the LinuxCNC forum is probably your best bet
    If you want to use Ethernet with a Mesa card, probably the easiest way would be to use your existing C35S breakout with a Mesa 7I92 (the 7I92 emulates 2 parallel ports connection wise)
    Note that your hal and ini files and LinuxCNC installation for a Mesa Ethernet card will be completely different from a parallel port installation so its not a trivial upgrade
  1. CNC4PC C11 Card and Huanyang VFD
    By Lasr Da Vinci in forum Controller Cards
    Last Post: 04-19-2013, 12:26 AM
  2. CNC4PC C1 parallel interface card problem
    By freemoore in forum Controller Cards
    Last Post: 01-19-2013, 11:10 PM
  3. Advice needed on video card upgrade
    By Gerry Sweetland in forum Solidworks
    Last Post: 01-15-2013, 04:39 PM
  4. cnc4pc C6 card and vdf
    By hudmut in forum Benchtop Machines
    Last Post: 10-02-2009, 03:47 PM
  5. CNC4PC C3 Index Pulse Card - Help
    By TravisR100 in forum CNC Machine Related Electronics
    Last Post: 06-30-2009, 01:50 AM
