584,874 active members*
5,364 visitors online*
Thread: Mirrored DXF
    Apr 2016
    9
    Mirrored DXF
    https://ufile.io/zsdoj
    When inserting this particular DXF in alphacam (2016 r2 64bit ver:15.5.0.133) elements of it are mirrored over other elements.
    When trying to open same file with any other CAD software (autocad, qcad, viewer.autodesk.com), the whole drawing is mirrored not only parts. No matter what i do from here, when inserting the dxf in alphacam is still wrong.
    The client from where i got this file, swear on his screen the drawing is not mirrored.
    Can somebody please explain why alphacam has problems when inserting this dxf? ( They sent me different dxf and dwg versions all with the same issue)
    Thanks guys!
    Dec 2013
    5717
    Re: Mirrored DXF
    I have had this happen with other CAM programs also. It seems to occur when there are blocks or especially rotated or mirrored blocks in the original drawing. Normally the fix is to explode the drawing before saving as a DXF.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2016
    9
    Re: Mirrored DXF
    Ty Jim,
    i don't have access to the original drawing, but i'll try to suggest them to explode it.
  1. CAD is printing mirrored.
    By Jcam in forum Esprit
    Last Post: 09-22-2014, 02:45 PM
  2. mirrored text
    By 9wleadfoot in forum Haas Mills
    Last Post: 05-21-2012, 08:39 AM
  3. Mirrored Engraving
    By Ecmdrw5 in forum Haas Mills
    Last Post: 09-03-2010, 06:45 PM
  4. Mirrored: What's going on here?
    By Sheridan Basses in forum Musical Instrument Design and Construction
    Last Post: 05-09-2010, 07:00 PM
  5. Output is mirrored??
    By BobLWeiss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-03-2005, 06:54 PM
