585,717 active members*
4,048 visitors online*
    Mar 2018
    13
    Smile DM4400 replacement belts
    Received replacement belts today.
    Item #T5-325
    13mm wide
    Bought them from Chris Connor
    Inside Sales
    Megadyne - Belt Corporation
    253 Castleberry Industrial Drive
    Cumming, GA 30040
    Phone: +1 (770) 887-9725
    Fax: +1 (770) 887-4138
    They were about $8 each.
    Cheers
    Don
    Mar 2018
    13
    Whoops wrong size. Should have cut one first.
    So I did cut one and laid it out flat and measured. It is 330.2 mm long (13") with 65 teeth. This makes it a XL belt with a pitch of 5.08mm or 0.2".
    Jul 2010
    172
    Re: DM4400 replacement belts
    Stock Drive Products has them too.
    They are 9.5mm wide but they work well.
    Timing Belts - XL Profile - Inch Sizes
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
  1. Replies: 9
    Last Post: 07-03-2021, 10:53 PM
  2. Powermatic variable speed drill press drive belts, and belts for others
    By 520052 in forum Uncategorised MetalWorking Machines
    Last Post: 09-04-2019, 10:19 AM
  3. Update from 6 belts to 2 belts
    By sdfoiler in forum Fadal
    Last Post: 09-12-2012, 02:28 AM
  4. Just got a DM4400
    By maddog1927 in forum Dyna Mechtronics
    Last Post: 08-24-2010, 02:27 AM
  5. replacement belts for Machinex mini lathe
    By gbuffon in forum Mini Lathe
    Last Post: 10-22-2006, 04:33 PM
