KL-1325L ATC CNC Router
https://www.automationtechnologiesin.../?preview=true
Working Size is 1300*2500*200mm ( 51.2 x 98.4 x 7.9 inch)
Syntech-6M Control System
China CC 9kW Air Cooling Spindle: 24000 rpm/min, Linear ATC with 6 Pieces ISO30 Tools
Vacuum Table with T-slot & 5.5kW Air-cooled Vacuum Pump
China 850W AC Servo Motor and Driver
Helical Rack and Gear Box
Fulling Brand 11kW Inverter
France Schneider Electric Parts
Japan OMRON Limited Switch
German Siemens OEM Factory Cable
Manual Control with Aluminum Oil Pipe
Under- Voltage, Missing Item, Phase Sequence, Overload Protection
Aviation Aluminum Alloy Thickening
Machine Max. Travel Speed is 40 m/min
Machine Size is 3300*2200*1750mm
1800kg Weight
220V 50/60HZ
Double Winding Film Packaging
One year Warranty
