586,009 active members*
4,950 visitors online*
    Mar 2017
    9
    Homemade 4th axis
    I have made up a 4th rotary axis for index cutting. Currently mach3 is controling the indexing and delta dynapath 20m is just looping a simple linear move with dwell.
    Is it possible to wire delta dynapath to comunicate with a closed loop stepper motor and drive? Maybe just using signals from i/o board?
    How would one go about the wiring?
    Jan 2009
    52
    Re: Homemade 4th axis
    You could update it to a 4th axis The dynapath puts out a +- 10vdc command. And takes a 5vdc squarewave feedback. Dynapath is still around. And services controls. Another place is parts and smarts in Wisconsin. Another option is if your machine has an m-code that turns on to start and allows an input to say it is done. Best of luck
    Mar 2017
    9
    Thanks Gwiz for the feedback.Will contact parts and smarts
  1. Homemade cnc machine 4 axis
    By phunguyen in forum CNC Wood Router Project Log
    Last Post: 03-23-2017, 01:59 PM
  2. Homemade 4th axis
    By snowluck in forum Drilling- and Milling Machines
    Last Post: 12-15-2013, 12:37 AM
  3. Homemade 5 axis cnc
    By gualalasmooth in forum Open Source CNC Machine Designs
    Last Post: 01-09-2013, 12:03 PM
  4. Homemade 4th Axis
    By BackyardWorkshop in forum DIY CNC Router Table Machines
    Last Post: 10-26-2009, 02:51 PM
  5. Homemade 4th (rotary) axis?
    By gearsoup in forum Mechanical Calculations/Engineering Design
    Last Post: 02-24-2006, 11:34 AM
