585,973 active members*
3,971 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Help HAAS SMTC Doble Arm Motor Problem
    Hello I am new to this site and hope I can get some help and maybe start helping others with any knowledge I might have
    I have a problem with the Side Mount Tool Changer Double Arm Motor
    I cannot get the motor to move the arm forward or backward in the recover mode. I have removed the motor to have it tested and the motor is working just fine. When I have the motor out I power up the machine and go into the recover mode so that I can see if the motor cam is turning and the first time I push atc fwd or atc rev the motor spins one time only. So only the first time I hit atc fwd does the cam turn. After that the motor is completely frozen and will not move at all. Any ideas what might cause this problem and what I should check to fix this issue? Is there a point on the IO board where I can check the Voltage being sent to the motor? Any help would be greatly appreciated as the machine is down and we must get it up and running soon.
    The machine is a 2004 HAAS VF 2 with Side Mount Tool Changer
    Thank you in advance
    Jun 2003
    1365
    Re: Help HAAS SMTC Doble Arm Motor Problem
    Did your cambox leak out all it's oil? The double arm seal degrades over time and if you don't replace and replenish the oil it can get dry in there.
    Nov 2007
    479
    Is the brake resister still in one piece?
    May 2018
    69
    To properly diagnose the problem, we will need more info about what is going. Just saying that you cant use the recover mode doesnt tell us anything.
    Why are you trying to use the tool changer recover? Can you do a regular power up restart? Are there any alarm codes? Did you crash the tool changer?
    As an FYI - The double arm motor is a hidden axis. The power doesnt come off the IO board, it comes from one of the axis amplifiers.
  1. 96 Haas VF2SS with SMTC Tool change problems
    By n0xx187 in forum Haas Mills
    Last Post: 02-04-2016, 07:34 PM
  2. Haas vfo mitsubishi spindle motor drive problem
    By s00073055 in forum Haas Mills
    Last Post: 11-05-2015, 08:43 PM
  3. 2008 Haas VF6/50 SMTC
    By BJSwart in forum Haas Mills
    Last Post: 02-15-2013, 03:11 PM
