585,764 active members*
4,143 visitors online*
Thread: Pump help
    40
    Pump help
    Hi I have a Flow pump with mechanical shifting , it intermittently stops shifting.
    On the hydraulic shift tubes one side gets hot the other is much cooler
    if some one has a flow pump can they please advise are the tubes hot or cold , this way i can work out which side is faulty
    peter
    Jun 2010
    463
    Re: Pump help
    Those shift tubes and springs need to be replaced, they can get worn out and that can cause erratic shifting.
  1. Replies: 0
    Last Post: 11-15-2017, 04:19 AM
  2. Replies: 0
    Last Post: 11-15-2017, 02:20 AM
  3. Vac Pump Help
    By redvanth in forum Chinese Machines
    Last Post: 09-15-2011, 03:52 AM
  4. Charge pump - do I need this on?
    By zeeway in forum Gecko Drives
    Last Post: 01-05-2010, 07:40 AM
  5. TM2 Coolant pump
    By Peter Gibbs in forum Haas Mills
    Last Post: 05-03-2008, 06:11 PM
