585,761 active members*
4,154 visitors online*
    May 2010
    122
    First Test Indicator
    I purchased my first test indicator and was wondering why the arrow isn't pointing straight up (refer to attachment)? I know you can move the face, but no matter what I do, if I move the measuring point through it's full range of motions, if I release it, the arrow always points to the same off centre location.
    Apr 2013
    1899
    Re: First Test Indicator
    There is no specific reason. It's just been made this way, and it doesn't actually makes a difference since you can rotate the dial to zero.
    Mar 2017
    314
    its scrap.
    please send it to me so i can make sure its disposed of properly
    actually it is offset just slightly in the unloaded state. So that when you actually load it against an article to interrogate, the pointer can be at 12:00.
    you buyin that?
    May 2010
    122
    Quote Originally Posted by generaldisarray View Post
    its scrap.
    I knew someone was going to say that.
    you buyin that?
    Ah I think I see, makes sense.
  1. spindle stop / mount test indicator
    By averageJoe576 in forum Taig Mills / Lathes
    Last Post: 05-22-2018, 03:12 AM
  2. Replies: 40
    Last Post: 03-17-2015, 04:34 PM
  3. Dial Test Indicator Flaw
    By Zirok in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2012, 08:04 PM
  4. I really havent seen such behaviour of dial test indicator
    By Ashish B in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2011, 10:39 AM
  5. Enco or Mitutoyo test indicator?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 01-03-2006, 04:38 PM
