585,922 active members*
3,677 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Control software/hardware compatibility
    May 2018
    7
    Hi all
    I'm trying to figure out what control setup I can use for my CNC router (a fairly old JCUT 1630B with Leadshine MA680H drivers). I'm having trouble with the PC that I'm currently using to control it (32 bit Windows XP with NCStudio) and I'm thinking of upgrading to a better control setup. I will be very grateful for some advice from someone with experience!
    1. Are these Leadshine MA680H drivers compatible with other control software (other than NCStudio)?
    2. If Mach 3 were compatible for example, can I run that on a normal modern PC (probably 64-bit) through the USB port with a USB to serial adapter? (The machine only has a serial port unfortunately)
    Please let me know if you need further info!
    Cheers
    Dec 2013
    5717
    Re: Control software/hardware compatibility
    Any system that will generate a step & direction output would be compatible with those drives. Mach3 would work, and there are other options. You will have to determine computer compatibility.
    Jim Dawson
    Sandy, Oregon, USA
  1. Which CNC and motion control software and hardware do you use?
    By machinekoder in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-05-2018, 07:55 PM
  2. Replies: 1
    Last Post: 03-17-2017, 11:45 AM
  3. Machine control software and hardware for RS-232 servos?
    By PaulMakesThings in forum Servo Motors / Drives
    Last Post: 11-23-2014, 03:08 PM
  4. Question: Software, Hardware or no flow control
    By salvadoralvarez in forum Okuma
    Last Post: 11-10-2010, 08:00 PM
  5. Control Software / hardware Reality check
    By DaveODonnell in forum Controller & Computer Solutions
    Last Post: 01-17-2010, 05:05 AM
