585,931 active members*
3,928 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > dc to ac servo motor upgrade
    Apr 2008
    204
    Can anyone chime in on difference between the two. I have keling 1100w servo motors now. If I went with 1000w ac delta servo motor is that a big upgrade or do I need to get the 1.5kw or 2kw if i want substantial upgrade.
    Jun 2011
    692
    Re: dc to ac servo motor upgrade
    What model do you have? I didn't think Keling identifies their DC servos by power.
    Probably not worth the upgrade unless you're having issues with the current servos. The biggest advantage of AC servos is longevity/reliability as they have no brushes to wear out. Also, Delta servo's generally have metric frames, not NEMA, so if you've got a NEMA 34 or whatever servo now you'll probably need a new mounting plate for an AC servo.
    Dec 2013
    5717
    If your existing system is working OK, I see no advantage in replacing servos.
    Jim Dawson
    Sandy, Oregon, USA
  1. Fadal ATC - servo upgrade possible?
    By realsquash in forum Fadal
    Last Post: 05-21-2015, 01:39 AM
  2. Amazing spindle motor upgrade package
    By jcposada in forum For Sale Only
    Last Post: 02-13-2015, 07:03 AM
  3. Servo upgrade benefit
    By erikjgreen in forum Servo Motors / Drives
    Last Post: 12-19-2012, 08:47 PM
  4. Axis servo motor vs. Spindle servo motor
    By iyerks in forum Servo Motors / Drives
    Last Post: 09-25-2012, 04:58 PM
  5. CNC Bridgeport whatever model servo upgrade
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2009, 01:47 AM
