Hi everyone, I wrote the program on Biesse editor, and save on bpp file, the program works good, but it starting cut from x0 y0 position, but i need some offset like start cut from x10 y10 (you know plywood sheets always bad on the sides). On the worklist, I click on the program right mouse button and select "Panel" where I can change the size of part, origin, etc. but where offset?? Maybe I should programmed offset on the editor? It should be very easy, but I can't find. Trying to do nest, where offset not a problem, but machine doesn't want work with nest file, perhaps some mistake.
Please help
