585,687 active members*
4,807 visitors online*
    May 2010
    122
    Header vs Setup Sheet
    I posted this in business practices, but didn't get any responses, hopefully this section has more traffic and I get more luck.
    Simple question, what is the difference between a setup sheet and a gcode header?
    Re: Header vs Setup Sheet
    A setup sheet is a document with information about the project and machining operations.
    https://www.cnccookbook.com/art-setup-sheet/
    The G-Code header is the block of codes at the beginning of a g-code program that sets the required modes on the machine.
    May 2010
    122
    I see, thanks Gerry.
    I think I get it now. A gcode header basically points to the correct setup sheet.
    I actually read another article on cnccookbooks that confused me:
    https://www.cnccookbook.com/g-code-b...ucture-blocks/
    But reviewing it again:
    "– Program file name.
    – Program author
    – Version date
    – Modification history–a line for each version telling what changed, who made the changes, and the date.
    – Machine and control the program is intended for
    – Units: inches or mm
    – Setup information: What stock material is expected, what size, etc.?
    – Work Coordinates: What’s expected by way of work coordinates? Where is Part Zero?
    – Customer info: Job shops will want information about what customer and job # the program is part of."
    There isn't as much overlap as I remembered after all. I think it's the stock material, work coordinates/where is part zero lines that really threw me off.
    I guess it could, but it doesn't have to contain any information that's in the setup sheet.
    A setup sheet is basically an instruction sheet for machining your part.
    You can add comments to the g-code with the same info, but it's not required.
    May 2010
    122
    Yep gocha. I just like Bob's way of putting it "A CAD File, CAM File, G-Code File, and a Setup Sheet might be all we need to fully document a program if there’s enough meat captured by the Setup Sheet." So going off this, I just wanted to make sure each component complemented each other, didn't contain redundant information and all 4 components were generated.
  1. Setup Notes in Program Header
    By aldepoalo in forum BobCad-Cam
    Last Post: 10-28-2013, 05:36 PM
  2. Setup Sheet
    By programmer4fcmt in forum Esprit
    Last Post: 12-08-2011, 10:17 PM
  3. Setup Sheet
    By grand master x in forum Mastercam
    Last Post: 06-25-2011, 06:39 PM
  4. Need a simple setup sheet for X3
    By foxsquirrel in forum Mastercam
    Last Post: 11-21-2008, 05:08 PM
