585,748 active members*
3,624 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > ESTOP IS ENABLED AND MACHINE IS STILL WORKING AFTER POWER RESET
    Aug 2017
    112
    Hi, Tom
    I am using Kflop Estop button it is wired on bit no 16 of JP4
    It is working and program for this is flashed onto kflop board.
    But after power reset if Estop is enabled still all axis are working.
    flashed initialize program is not checking for EStop bit.
    How to make estop bit checking enable everytime when i power up the machine. ?
    waiting for your kind reply
    THANK YOU
    Regards
    Amit Kumar
    May 2006
    4045
    Re: ESTOP IS ENABLED AND MACHINE IS STILL WORKING AFTER POWER RESET
    Hi Amit,
    Do you have the Thread configured to launch on Power up?
    See:
    Configuration Screen
    Regards
    TK
    http://dynomotion.com
    Aug 2017
    112
    Quote Originally Posted by TomKerekes View Post
    Hi Amit,
    See:
    Regards
    Yes i Have enabled that option for thread to launch on power up.
    Regards
    Amit Kumar
    May 2006
    4045
    Hi Amit,
    Did you set Launch Thread #1 on Power Up before you Flashed User Data?
    Did you check if the Thread is running after you cycle power?
    Connect the USB, run KMotion.exe, check the C Programs Screen to see if there is a Green Bar over Thread #1.
    Regards
    TK
  1. DRO reset to zero if the Estop or limit switch are hit
    By mac7988 in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-16-2016, 07:59 PM
  2. Dynapath 10/20 Estop no reset
    By ctroyer in forum Dynapath
    Last Post: 04-23-2016, 01:42 PM
  3. Replies: 29
    Last Post: 10-08-2014, 08:48 AM
  4. nm200 estop not working
    By urbanimports02 in forum Novakon
    Last Post: 05-28-2011, 01:46 AM
  5. Mach3 External Estop Reset
    By bcromwell in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2006, 05:16 AM
