I made the mistake of trying to remove an NSK LS25 block from the rail and as soon as it got the end all the ball bearings fell out and rained on my carpet. Now I can't put them back in.... I haven't had this issue before as I guess all my other bearing blocks are the caged type.
Does anyone know how to put the balls back into a non-caged block and get it back on the rail without knocking them out again? I have tried everything I can think of...
The NSK manual says "if a ball falls out then put it back in". The problem with that is that the rail knocks most of the balls out of their grooves when I try to slide it back on....
