585,996 active members*
4,878 visitors online*
    Jan 2015
    23
    welder wire feeder
    Hello, I was hoping someone could give me some feedback on whether or not it would be necessary to insulate the shaft of a stepper/servo being used as a wire feed for a high frequency pilot Arc start plasma arc welder. I'm concerned about the high frequency high voltage arcing across the rotor and stator and frying out the drive.
    Any help is greatly appreciated!
    Re: welder wire feeder
    Hello there,
    You should insulate the shaft!
    Leaving it without insulation leaves you at risk of electric shocks or worse still electrocution. Please do insulate it
    Hello there,
  1. Bar feeder oil choices to help with vibration inside the feeder channels
    By lasernerd in forum CNC Swiss Screw Machines
    Last Post: 05-19-2017, 10:59 PM
  2. wire feeder
    By 0Jw in forum Other Machine Topics
    Last Post: 03-18-2017, 05:36 AM
  3. TIG Cold Wire Feeder MILLER DYNASTY 200 DX aluminium welding DIY
    By pinciui in forum Welding Brazing Soldering Sealing
    Last Post: 03-15-2012, 01:42 AM
  4. dc stick welder to tig welder
    By kaighn80 in forum Welding Brazing Soldering Sealing
    Last Post: 08-27-2010, 12:43 AM
