585,676 active members*
5,543 visitors online*
IndustryArena Forum > Hobby Projects > Gunsmithing > Looking for some help!!
    Dec 2014
    5
    Any one out there have gcode for a AR-10 80% milling operation?
    I prefer TXT files.......but maybe someone can help.
    Mike
    Oct 2017
    27
    Quote Originally Posted by machinist505 View Post
    Mike
    Hmm, mine is coded for a dynapath. If I have time this weekend I can write some generic g-code. It's not that hard, you can find a blueprint online. Though without a tool list to know carbide or hss em, # of flutes, etc. the feeds and speeds are useless. Also fixture offsets and tool numbers,etc. Sometimes it's harder to fix someone else's work than just do it yourself.
    - - - Updated - - -
    Mike
    Hmm, mine is coded for a dynapath. If I have time this weekend I can write some generic g-code. It's not that hard, you can find a blueprint online. Though without a tool list to know carbide or hss em, # of flutes, etc. the feeds and speeds are useless. Also fixture offsets and tool numbers,where is program zero, etc. Sometimes it's harder to fix someone else's work than just do it yourself.
    Jul 2016
    660
    Re: Looking for some help!!
    I have mine and it`s a mirror finish, unlike the original M4A1 Lower which had some scratches on it. I can code it for you if you want this is only done by a CNC 6040 with a 2 flute carbide bit, 8mm wood router @ 24K RPM
