Originally Posted by
Travspad
Hi Guys,
I have had a very frustrating weekend and nearly blew my VFD and Spindle Motor. Hopefully this will help somebody.
I followed all the online advise to program and wire the spindle but just could't get it to spin properly, I would have to spin the motor by hand to get it going?? I figured I might have a faulty phase on the motor as I'd double checked the wiring it seemed all good. The last thing I tried was adding an earth cable to the motor housing. Once you open the casing you realize how important this is as the water lines are not that well sealed or isolated from the power. Anyways once I fitted the earth cable I plugged everything in and tripped the RCD in my shed, I thought I'd really done it this time! Surely there is only one thing this could be...
It turns out the aviator plug was either a reject or assembled incorrectly at the factory. The PIN numbers did not correspond between the male and female plugs.....
I'm thankful I got out of this one alive, (and the spindle).
I hope this helps somebody...
Regards,
Travis
