585,982 active members*
4,644 visitors online*
IndustryArena Forum > Community Club House > Facebook Group Discussion > Huangyang Model HY01D523B different from others.
Results 1 to 6 of 6
    Jul 2017
    57
    I purchased a 220v 1.5KW VFD last year and have only now been able to use it. The screw terminals for R, S, T ; U, V, W & ground are not labeled and the setup is different from examples online of those who have the very same model. Others have 2 rows of the green controller terminals and mine has just one long row. Others have a total of 9 screw terminals on the R,S,T, U, V, W row (usually with terminal for grounding and a brake resistor). Mine has only 7 terminals and the terminals are not labeled. There is a sticker on the outside of the VFD, but on the inside there are 2 embossed symbols (the only apparent labeling of the RST-UVW row that has any apparent labeling) indicating that the 2 outside screws are ground. Has anyone seen this setup and know which terminals are which?Click image for larger version.
    Jul 2017
    57
    Re: Huangyang Model HY01D523B different from others.
    Quote Originally Posted by Gallen66 View Post
    That's a knockoff or copy, not a "genuine" Huanyang.
    Jul 2017
    57
    Thanks for letting me know. I wasn’t sure. I actually got it to work, though I had to guess which terminals were which. It seemed to run. Unfortunately, I had to buy a genuine Huanyang 2.2 KW VFD to run with my 2.2 KW spindle.
    15362
    Yes it is not a Huanyang, it may be a Askpower, do the parameters start like this Pn0
    Mactec54
    Jul 2017
    57
    To mactec54:
    I’m not sure. I finally got it to work after following the printed label on the front. It functions, but I won’t be able to use it because it is a 1.5 KW VFD and my spindle is 2.2 KW. I bought a “genuine” Huanyang that matches my spindle. After spending all that time trying to figure out how to wire up the VFD with conflicting terminal labels it didn’t take me too long to wire up the new one. So, with my axes now working and my spindle wired, I plan to attempt some initial cuts some time next week!
  1. Where can I get a manual for Huangyang 2.2 KW
    By futureform in forum Spindles / VFD
    Last Post: 09-07-2016, 11:31 PM
  2. Huangyang vfd HY07D543B 7.5 kw
    By BigDadyD in forum Phase Converters
    Last Post: 08-27-2016, 05:53 AM
  3. Quastions about HY01D523B with 1.5KW 220V
    By bergstar in forum Spindles / VFD
    Last Post: 04-18-2016, 02:58 PM
  4. OV-2 on hy01d523b
    By massimomanco in forum Phase Converters
    Last Post: 02-22-2015, 12:07 PM
  5. Huanyang HY01D523B help please?
    By Tony344 in forum Spindles / VFD
    Last Post: 10-22-2013, 01:27 PM
