585,762 active members*
4,198 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > What else do you need to run AC servo motors?
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    15362
    Re: What else do you need to run AC servo motors?
    [QUOTE=Goemon;2190838]Are the SGDA drives the only ones that would work? Should I assume that others like the SGDS will not work?
    How much would you pay for a used SGDA max?
    can you use a 750w drive with a 400w servo or does it have to be a 400w drive for a 400w servo?[/QUOTE
    As you thought SGDS will not run a Sigma series Motor
    How much to pay can be if they are new or used from $60 to $150 would be a normal range
    Yes you can use a larger Servo Drive but there is a max to this also, usually a max of 2 drive sizes above the motor you are using, so 750W would be the max
    The important part is the P for position control, SGDA-04AP are the Drives you want for Step / Dir
    I have some new Drives in stock, but they are SGDA-04AS, these are for +/- 10v control
    Mactec54
  2. #22
    Mar 2017
    926
    I found (and bought) 2 new 400w SGDA drives for $80 a piece. The others I saw were all a lot more expensive (and used).
    I'll keep an eye out for a deal on a third drive but I'm going to use 3.5a Nema 34 steppers with my Gecko G540 in the meantime so I don't delay my build any further while I figure out the servo thing. The Nema 34's have a longer shaft so it can reach the coupling once I mod the actuator housing.
    I am assuming that there is no info out there on my servos because they were a custom order from NSK for their actuators. I feel like I have a lot of reading to do before I can use them.
  3. #23
    15362
    Quote Originally Posted by Goemon View Post
    That was a good price for new, the other tip for drive selection is if you see one that is SGDA-04A with no other letter after it, they do both Step /Dir and analog +/-10v for controlling them, so either a P or nothing at all
    It will only be the encoder PPR that will be different, so not much to worry about, the only thing that is important is they are wired correctly, and the manuals are very good at showing wire connections, for these Yaskawa servos
    Mactec54
  4. #24
    Jun 2011
    692
    I think someone said earlier you can't mix servos and steppers. This isn't really true, if you're using step/dir, a servo and a stepper don't look any different to the controller.
  5. #25
    Mar 2017
    926
    Quote Originally Posted by skrubol View Post
    I was planning to try it to see for myself anyway. I don't really know how programs like Linux CNC deal with feedback from a servo motor. The way they receive steps should be the same. I just don't know what happens if you miss a step on one of the servos but have no data fed back from the stepper. I don't know if you can use a servo in open loop mode
    I am also interested to see what happens if you mix different brands of servo motors. E.g. If you used two Yaskawa with one Mitsubishi as it is easier to find bargains if you can mix and match.
  6. #26
    With a step/dir control, you can mix and combination of steppers and servos.
    Most if not all step/dir servos close the loop in the drive, so the control is always running open loop.
    You can close the loop in LinuxCNC, but you'll have to feed the encoder signals from the drive back into LinuxCNC.
  7. #27
    Jun 2011
    692
    There are 2 different basic ways to communicate with a servo, step/dir (control isn't in the loop, behaves just like stepper,) and encoder/pwm (servo drive tells the control where it is and the control tells the servo drive how fast to go or how much torque to generate.)
    Servos still won't 'miss steps', even in step/dir mode. They may fall behind a bit where more torque than they can generate is needed, but they will either catch up when the load lightens or fault and stop completely. You will definitely want the fault line properly wired back to your control.
    I'm not sure what it takes to mix step/dir and closed loop in LinuxCNC. I'd guess it's possible, but maybe difficult? (I'm still in the research phase on my LinuxCNC projet as well.)
  8. #28
    15362
    I don't think anyone said that, you can mix any combination you want, and can even mix control method's if you want, there are no real constraints, on how you can use either Step/Dir or analog
    Mactec54
  9. #29
    15362
    That sure is not correct, a servo will never behave just like a stepper, the loop is closed in the servo drive, and is just as affective as closed in the control
    Mactec54
  10. #30
    Jun 2011
    692
    I misspoke, I should have said is controlled just like a stepper (in step/dir mode.)
Page 2 of 2 12
  1. Simple Servo questions- Do all servo motors use differnt drivers?
    By ltortuya in forum Servo Motors / Drives
    Last Post: 11-04-2015, 07:38 PM
  2. servo motors or stepper motors for ATC machine
    By Fanny-Roctech in forum Roctech CNC Routers
    Last Post: 04-21-2015, 03:29 AM
  3. Servo driver for Fanuc Model 5 servo motors
    By AlMolp in forum Servo Motors / Drives
    Last Post: 06-08-2014, 08:42 PM
  4. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
