585,973 active members*
3,899 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Heidenhain TNC145 Fusion 360 Post, Incorrect End of Circle
Results 1 to 1 of 1
    Oct 2013
    10
    Trying out post processing in Fusion360 for my Bridgeport R2C3 with TNC145 controller. I drew up an Octagon as a contour test.
    Fusion360 spits out a gcode with c and cc code. And after uploading and trying to run it on my machine, it gives me an Incorrect End of circle error.
    I'm attaching my post processor, f360 dwg file and the gcode result.
    Can someone familiar with this setup please advise? I really don't want to rip out the electronics and upgrade it as of yet.
    https://a360.co/3IFHtmy
    Thank you.
    Attached Files Attached Files
  1. Heidenhain iTNC530, solution for CIRCLE END POSITION INCORRECT error
    By ncmatic in forum Uncategorised CAM Discussion
    Last Post: 01-18-2022, 04:19 PM
  2. Fusion 360/Mach 3 Gcode program end code help
    By dkp_design in forum Autodesk
    Last Post: 07-04-2020, 02:18 AM
  3. circle end pos. incorrect
    By knowlesy in forum G-Code Programing
    Last Post: 06-21-2015, 10:58 AM
  4. circle end point incorrect/ machine parameter
    By ANI-MAT in forum HEIDENHAIN -> TNC
    Last Post: 12-21-2011, 12:53 PM
  5. CIRCLE END POSITION INCORRECT
    By brad white in forum Dolphin CAD/CAM
    Last Post: 12-01-2009, 09:20 PM
