585,991 active members*
6,343 visitors online*
    Jun 2007
    99
    GX1000 Spingle Lubrication
    I have the GX1000 OSP vertical mill. At the top of the Spindle motor is a fan and over time, grease has escaped. Is there a way to add more grease? The maintenance manual appears useless unless I overlooked a chapter. I use the machine a few times per week and I seldom run the spindle over 8000 rpm. Thanks.
    Feb 2005
    69
    Re: GX1000 Spingle Lubrication
    What you are seeing is probably coolant residue coating the fan, especially if you use high pressure coolant. Keep all of the fans clean, like on the heat sinks for your drives and any motors. You don't need to grease fan motors.
    The GX Hardinge line with OSP controls didn't go over very well. If a customer wanted Hardinge they preferred Fanuc, and if they wanted Okuma controls, they generally bought a Genos.
  1. Bridgeport GX1000 OSP is this the right forum?
    By Edster in forum Bridgeport / Hardinge Mills
    Last Post: 05-12-2014, 01:31 PM
  2. Lubrication
    By Bob La Londe in forum Linear and Rotary Motion
    Last Post: 04-25-2014, 07:48 AM
  3. Lubrication
    By BESTCO in forum Tree
    Last Post: 05-31-2013, 01:57 AM
  4. Lubrication !
    By zaebis in forum Novakon
    Last Post: 02-07-2010, 09:09 PM
  5. Bridgeport GX1000
    By sunnybank in forum Bridgeport / Hardinge Mills
    Last Post: 11-25-2009, 04:03 PM
