585,948 active members*
3,645 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Z zero at top or bottom of work piece??
    Jul 2009
    Just started using my first CNC router and using Vectric Aspire for my tool path generation etc. Just wondering what the general consensus is about where to locate the Z reference, top or bottom of your work piece.
    Dalob
    Nov 2012
    1267
    Re: Z zero at top or bottom of work piece??
    I don't think there is a "general consensus". People use whatever is more convenient for the particular situation.
    For instance, when you engrave something, it may make more sense to reference on the surface of the part.
    When you are cutting out a shape all the way down to the worktable, it may make more sense to reference on the worktable.
    Jul 2018
    6
    I've found it easier to Z Zero on the top of the material, but doing doubled sided projects, it's best to Z Zero off the bed. it centers your models, if you material is a little thicker than you put in the parameters, it could be off a little. going off the bed will be right on.
  1. Squaring work piece
    By Garciabyron218 in forum Uncategorised WoodWorking Machines
    Last Post: 06-22-2018, 12:31 PM
  2. Machining all of the work piece
    By sdh600 in forum SprutCAM
    Last Post: 05-13-2016, 09:54 PM
  3. Master Cam Tappered wall. Work from bottom up?
    By Twin-10s in forum Mastercam
    Last Post: 05-06-2016, 09:10 PM
  4. CNC tries to work from bottom of material
    By dmcgarry in forum PhotoVCarve and VCarve Pro
    Last Post: 04-13-2015, 06:08 PM
  5. Jagged edges at bottom of milled piece
    By chillydk147 in forum Chinese Machines
    Last Post: 08-12-2013, 12:44 PM
