Hello,
I’m working on an application where 5 ICD B8001 drives with B41 servomotors are used. This application used step and dir to control the movements of 5 linear actuators. I would like to change this in order to use a +/- 10V analog command with an external position loop (PLC modules + PC). I have made some trials but I’ve got problems.
I attempted to cancel the offset on one drive (configured with analog input) by algorithm but it only works if the other 4 drives are disabled. If the other drives are enabled and configured with step and dir inputs, the offset can’t be canceled and the actuator keeps moving weakly and not linearly (visible with the encoder signal) while the others are stationary. If the other drives are enabled and configured with analog inputs (0V at inputs), all of the actuators are moving strongly. Is it an EMC problem or is there another possible reason?
I have used different configurations but the last one is:
• Encoder and power signals are shielded at both sides (between motors and drives).
• PLC modules are supplied with 24V DC supply with transformer on the main, but same power supply as drives.
• Analog PLC modules are +/-10V single-ended outputs connected with twisted-pair cables. The shield is connected to the isolated analog ground of the module and to the analog ground of drive. Analog out (module) to Command + input and analog ground to Command – input.
• Encoder feedback uses also twisted-pair cables. The shield is connected only to the 0V of the modules supply and the 0V modules supply is also connected to the common input of the drive. Module inputs are differential inputs.
• It seems that the drives (single phase) are supplied from three phases in order to balance phases.
Do you have any idea what could be the origin of these problems or how to solve it?
Thanks a lot.
