585,978 active members*
4,586 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > 6.5w air solenoid directly to g540 without relay?
    Nov 2017
    591
    setting up my mist coolant with g540, mach3. my air solenoid is rated at 6.5w (0.54a, 12v). g540 output can handle up to an amp right? so should be fine without a relay? or bad idea?
    Aug 2005
    1092
    Quote Originally Posted by QuinnSjoblom View Post
    Yes you should be fine to drive the solenoid directly. The G540 outputs also have the fly back diodes built in as well.
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    Nov 2017
    591
    Quote Originally Posted by phomann View Post
    Cheers
    Peter
    Excellent, thank you. That will clean things up nicely. One more question, if I ever add a second solenoid, is it 1 amp limit per g540 output, or 1 amp total for all outputs?
    Aug 2005
    1092
    Re: 6.5w air solenoid directly to g540 without relay?
    Yes it is 1A per output.
    Cheers
    Peter
    24221
    Another method if a VFD is used, is to operate the solenoid from a VFD output which can be either set to turn on/off by the At Zero or At Speed parameter.
    A manual SW can be introduced if over-ride is needed.
    Al.
    Albert E.
  1. VFD P24 to G540 using a Relay
    By district7 in forum Spindles / VFD
    Last Post: 04-25-2015, 06:56 PM
  2. Gecko G540 - Styre solenoid ventil
    By henrikm in forum Norwegian
    Last Post: 01-06-2015, 11:36 AM
  3. Relay timer for solenoid.
    By moto52000 in forum CNC Machine Related Electronics
    Last Post: 12-04-2011, 06:54 AM
  4. Gecko G540 Relay's Need Help
    By The CNC Man in forum DIY CNC Router Table Machines
    Last Post: 02-09-2010, 12:16 AM
