585,722 active members*
4,166 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Foam cutter XY using DC motors with encoders
Results 1 to 6 of 6
    Jun 2018
    Hello all, here is the story...
    I started to build CNC foam cutter, since I got hold of some parts from old machines I would like to try using them...cutter will have 2 X axles and 2 Y axles. Trying to use Maxon DC motors with HEDS-6310 208 B encoders from Mydata TP9. After encoder there is board with 74HC368D. Power supply line to motor have symmetric linear filter. Can Arduino handle all this in combination with some cheap drivers(lets say L298N)...
    encoder pinout attached...
    any hints are welcome
    Apr 2004
    733
    https://www.youmagine.com/designs/dc...ware#!comments
    I tested this code a few years ago. It works for very basic brushed motor control.
    https://youtu.be/aauSVJ1OSt8
    Jun 2018
    11
    Uh,you produce foam?EPP or EPS?
    Jun 2018
    Re: Foam cutter XY using DC motors with encoders
    Quote Originally Posted by laser-machine-parts View Post
    nope, this is just hobby project to cut EPS foam...
    Jun 2018
    @jfong
    thanks a lot, any idea how to add slave motors?
    Apr 2004
    733
    Just use multiple Arduinos/l298 and combine the step/direction lines.
    This will control 2 or more steppers from the same pulse.
  1. Replies: 0
    Last Post: 05-13-2015, 01:18 PM
  2. What encoders to use for these motors?
    By Cold Fusion in forum Servo Motors / Drives
    Last Post: 06-03-2005, 05:14 AM
  3. Using a controller and motors from a foam cutter
    By Quicker in forum DIY CNC Router Table Machines
    Last Post: 04-08-2005, 10:06 PM
  4. Stepper motors, encoders...
    By runnoahrun in forum CNC Machine Related Electronics
    Last Post: 02-29-2004, 04:59 AM
