585,712 active members*
4,229 visitors online*
    May 2013
    MADCAM Update
    Hello everybody,
    An update has been posted. The library folders are here:
    C:\ProgramData\madCAM AB\madCAM\6.0\Machines
    Re: MADCAM Update
    hello all , with the new last 2 updates i always get a problem with simulation , for that i use the last update of the 10-2017 ( attached image showing the problem ) , and another problem is when i choose the stl model to do toolpath the box-region size will be exactly the same as the model , but if i rotate the working 180 degree using ( inedexed 4 axis ) the region-box will be bigger and i should go to the BOX REGION sellings and do changes manulay and put the size that should be .
    thank you
    jeries facouseh
  1. 2017.10.19 madCAM update won't install
    By Corvus in forum MadCAM
    Last Post: 10-26-2017, 06:15 PM
  2. madCAM July 2017 Update
    By Mauri R in forum MadCAM
    Last Post: 08-16-2017, 01:46 PM
  3. Replies: 18
    Last Post: 08-03-2017, 11:53 AM
  4. Replies: 1
    Last Post: 05-24-2014, 02:57 AM
  5. Replies: 5
    Last Post: 03-27-2014, 08:13 PM
