584,858 active members*
4,989 visitors online*
    Feb 2007
    9
    Gerber Dimension 200
    Just got an older Dimension 200 with Omega 2.5 and ArtPath but having problems with the Z holding its depth. I set the cut depth maximum to .25 and after about 45 seconds into the job, it starts diving to around .5 or .75.
    Can anyone help?
    teemac
    Apr 2007
    35
    Upgrade the software, Had the same problem with Advantage 4.1. went to Omega and that cured it.
  1. G & M Code on a Gerber Dimension 200
    By quaturbo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-16-2012, 01:15 AM
  2. Tool holder dimension parameters?
    By MichaelHenry in forum SprutCAM
    Last Post: 12-23-2006, 09:43 AM
  3. dyna 2800 dimension
    By ataxy in forum Benchtop Machines
    Last Post: 10-21-2006, 10:40 PM
  4. Changing object dimension
    By JRoque in forum Rhino 3D
    Last Post: 05-25-2006, 02:52 PM
  5. Cutter dimension dilema
    By Moondog in forum Mach Software (ArtSoft software)
    Last Post: 04-28-2006, 02:12 PM
