585,967 active members*
4,454 visitors online*
    12mm Porcelain Slab advice
    Porcelain slabs are very new to the industry, so i thought i'd ask ANYONE out there if they could help me.
    Looking at getting a second-hand CNC (Zeus - 3-axis CNC), for a steal!
    Wondering if its possible to cut 12mm porcelain slabs with a router bit instead of purchasing a separate saw????
    Apr 2004
    5737
    Re: 12mm Porcelain Slab advice
    Stick with the saw, if you're making straight cuts. The only reason to use a router would be to make fancy cuts a saw couldn't do. But it would be a lot slower.
    Andrew Werby
    Website
  1. Smallest CNC BT40 bit for cutting porcelain?
    By dankiop72 in forum Australia, New Zealand Club House
    Last Post: 06-29-2018, 09:03 AM
  2. Stone Slab Resurfacer
    By newerastone in forum Mechanical Calculations/Engineering Design
    Last Post: 05-04-2013, 12:12 AM
  3. (Laser) Machining Porcelain
    By Zathras in forum Glass, Plastic and Stone
    Last Post: 12-05-2007, 07:23 AM
