Good morning,
Up 'till now my micromill has been working well. I am using it to cut out small plastic panels for a Hammond plastic box. I have done over 100 panels and have had no problem until today. Yesterday I was cutting out a panel to support a micro USB connector - no problem, made 11 panels. I turned the unit on his morning to cut out more panels, set the zero up, loaded the file, and turned it on, but instead of the Z axis moving up, in my case 8mm, it moved down and tried to plunge the cutter into the jig - not desired. The x and y axis appear to be OK but the z axis is moving opposite direction. The program has not been changed so what do you think I am I doing wrong? This have not happened before.
Bob
