585,902 active members*
5,159 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Redsail Laser > Redsail M500 wont fire, only when axis is moving, with details!
    Hi Everyone,
    I´m getting crazy and would love any suggestions from you guys!
    I have a Redsail M500 laser engraver with only a few hours of use, everything good untill today. I started it in the morning and the laser tube is not firing.
    I´ve done a bunch of research and testing but I can´t find anybody that has the same case as me.
    Things that I tested and don´t think they are the problem:
    - When machine is on, I press the "pulse" button and I get no response, also I press the "test" button directly from the Laser power supply and no beam neither, BUT when I disconnect the data cable from the laser power supply and I press the "test" button, the laser fires. CONCLUSION: I guess the laser tube is good and the Laser Power Supply is good too.
    - That data cable is directly connected to the Motherboard TL-403CB, which if I disconnect it from the motherboard it will fire aswell using ONLY the "test" button on the Laser Power Supply. (So there is something that is stopping the laser to fire, even from the "test" button when the data cable is plugged)
    - The curious thing is: whith everything connected, when I move the axis X or Y with the arrows in the panel and I fire the laser tube from the "test" button IT FIRES but not from the "pulse" button on the screen.
    I looked at the fuse and it is good, I don´t know what to do anymore, any help will be greatly appreiated.
    Oct 2014
    9
    Re: Redsail M500 wont fire, only when axis is moving, with details!
    Hello,
    It seems to be a bad wiring, refer to your motherboard manual for wiring diagram Generally the Low Input is connected to TL port (sencod on the PSU) Water protection on the third , ground in the 4th and A1 or PWM+ in the IN (which is 5th port)
    first and last port are alone in the Redsail M500,
    are you located in Venezuela? I had the same problem while replacing the PSU as I've changed to a different model
    Best,
    Total Stamp Caracas
  1. Redsail M500
    By SHADOW042 in forum Redsail Laser
    Last Post: 04-18-2020, 06:57 PM
  2. REDSAIL M500
    By tsotos in forum Redsail Laser
    Last Post: 07-28-2016, 04:36 AM
  3. HELP Redsail M500
    By MajorLaser in forum Redsail Laser
    Last Post: 12-29-2015, 03:33 AM
  4. Redsail M500
    By barriesign in forum Redsail Laser
    Last Post: 02-19-2015, 12:47 AM
  5. IEHK IE-500 vs. RedSail M500
    By AudubonCreek in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-17-2009, 05:13 PM
